starting problems when engine is hot
melb
I have a 1997 Johnson outboard 60 hp. When cold, engine turns over easily. When hot and left to cool down for 30-60 minutes or so engine cranks very slowly. It will eventually start but is very frustrating. Only happens after engine is hot. I can leave it for a month and it will start up right away but every time after running it for a while and letting it cool it cranks very slow and takes about 60-90 seconds of slow cranking before it will start. I have tried new batteries, cleaned and tightened all battery and starter terminals, new plugs, new fuel filter but nothing works. Any suggestions?
Mel
jakedaawg
If you mean by cranking slow that the starter is actually producing less RPM's when it is warmed up vs. when its cold then chances are you need a new starter.
