I have an 89 Force 85 hp. When starting cold I squeeze the bulb until hard , then push in the choke. As soon as it fires I have to keep squeezing the bulb, otherwise it dies. After a couple of minutes it finally keeps on running without bulb. I suspect that maybe the fuel pump maybe stretched, initially struggles to pull enough gas to fill the carbs? <br /><br />Paul<br />89 Force 85 on 17'Bayliner cuddy
