starting problems, slow turn over
70506
I have a 2004, 25 hp, 4 stroke, electric start (F25ESHC), I have replaced the starting battery, the starter is very very slow to turn over the engine. Is the starter relay going out, or other part? Once it does turn over, it will start and runs just fine. The problem is that it is very very slow to turn over, like if the battery is weak, I have checked the battery at the shop, good voltage, 800 cold cranking amps. Any suggestions?
JB
Re: starting problems, slow turn over
Ahoy, 70506.
Welcome to iboats. :)
Clean all connections in the battery to engine cables. Let us know what happens.
