Engine won't start other than wiggling the shift lever in neutral will sometimes work to allow starting. Sometimes it won't work at all yet other times the key will start the motor right away. I'm assuming this is the cause of a bad in-gear-protection-starter-switch. If this is so, where is it located and how is it changed?
