I need help since my ideas to find the problem has run out.
Background
I have an wellcraft 218 Coastal equipped with an Johnson 1995 200hp engine. I has always been fairly easy to start but now it wont even ignite. The problem started at the end of last season where I was forced to use starting gas to start it.
Took it out of the water at the end of last season. Checked the engine and pretty fast found a clogged solenoid. Cleaned it and ordered new sealings from ebay. Put everything together and tested the engine on land this season. It started so I thought I had solved last years mystery. Thinking it didnt choke.
Put it in water and it was VERY hard to start. Now it is in the harbour but wont even start. The only times I have managed to start it is when I use almost full throttle and choke. If I get it to start it runs pretty bad, shaking and sounds bad. Dies on idle or even before idle.
This is what I have done
Checked sparks on plugs, blue and nice (the plugs are new)
Tried new fuel from a can to exclude bad/ old gasoline
Checked fuel hoses for leaks
Checked compression, fine
Changed filters (fuel and fuel water separator)
Took carburators of, and cleaned them (took 2 apart to see if they were ok)
Took VRO pump of to see if the membrane was ok
Looked on cables on engine hoping to see any obvious brakes
Took solenoid of cable thinking it mayby was using the choke all the time.
I have run out of ideas. Any suggestions?
Background
