Hey guys I have a 1990 Baja with a 454 mercruiser. The boat is in excellent shape and i never had a problem with it. all of a sudden i had to turn the key a dozen times before starting. once it started cranking it fired right up. Now the boat wont start at all, not a click, nothing. acts like i dont have a battery hooked up. i changed that starting silanoid on top the motor, i have 12 volts on both batteries which are new this year, when the boat starts to crank it fires up instantly, so the starter doesnt seem to be bad....im thinking the actual key cylinder ignition itself. do these go bad?? i believe its origional
