Starting my 1967 9.5 HP Johnson
Knudy75
When I pull the recoil to start the engine, and it doesn't start, I notice a white film in the water and it smells like gas. The motor starts and stays running but when I stop and then try and start it again it takes a while to get it running and sometimes it just won't. Any suggestions? :confused:
tashasdaddy
Re: Starting my 1967 9.5 HP Johnson
film is gas and oil. have you check spark on both cylinders, when was your carb last cleaned and a rebuild kit installed. have you ever checked compression. it takes these 3 things in proper ratio, for it to start easily, and run correctly.
Knudy75
Thank you I'll Give these things a try.
