starting issues
Xenon012
hello i have a 1991 25 HP evinrude tracker Model number is TE25ELEID im having a hard time getting the motor started but once i do the motor has no problem starting the rest of the day untill it sits for a day or more?. i just cleaned the carb and put a new carb kit in also new spark plugs whats next ? thanks all for your help
Are you advancing throttle for cold starting ?---Are you pushing the key in while cranking it over ?
There is no choke lever on that motor.--------Is your electric primer working ?----Have you tested operation of the electric primer valve ?
Xenon012
have not tried that i shall do that.. but first there no choke lever then what is this ? thanks
boobie
That's your throttle warm up lever. Has nothing to do with the choke.
oldboat1
new plugs won't do it if the ignition isn't doing its job. Get a spark tester, and see if there is spark produced when the motor is refusing to start.
