Starting Issues w/200HP Opti's
Wild Bouy
I have twin 200HP opti max's, they are 2001's. In the warm weather they run like a couple of raped apes, but when the weather is cooler, say 40ish or lower, one motor will not start. I tries to kick over but won't. Even if I shoot some starting fluid in it, it'll only run until the fluid is gone. I've changed the plugs, gas filter, air filter, cleaned ALL battery connections. I even thought maybe the gas line may have had a hole, so I changed that as well. Now I can get by puttering with one motor to our Striper spot which isn't far from our dock, then later on in the day when the weather warms a bit the troubled motor starts like there was never a problem. Anyone have any ideas??
Thanks in advance for any advice.
boatguya1
Re: Starting Issues w/200HP Opti's
You need to make sure the ecm is seeing the correct motor temp. A scan tool to see if the motor ecm see's the correct ambient temp would be ideal. Also if you have the gauges with the digital displays I believe you can toggle through and get the temp the ecm is seeing.
If not that check the airpressure from the compressor.
James
Wild Bouy
James
James,
Thanks for the tip, I will try your suggestions.
