I have a 1974 85 hp Johnson on a 1979 16' Sea Star that I just can't seam to completely figure out. I bought the boat and motor a few months ago and because there was old gas in the tank I immediately flushed out the tank several times even though it wasn't very dirty. Installed new fuel lines and clamps from tank to motor...new primer ball, and quick connect on motor. New fuel filter and interior lines. Also thouroughly cleaned the carbs and installed new plugs. Motor has strong spark.
Motor runs excellant low and top end but it always take a while for the fuel to get to the cylinders on cold start. For cold start I full choke with a little throttle until it fires then release choke. Have to do that few time until it will stay running. Just not getting the gas that I should right away. Also if I stop to fish more than 5 minutes I have to do the same thing over again. I really shouldn't have to choke it again when the motor is warm. I am leaning towards a weak fuel pump but don't want to spend more money on something that isn't the problem.
Has anyone had this similar problem with this motor? Any info would be great...the motor runs strong and idles like a champ once I get enough fuel to it. Thought about taking it in to the mechanics but would like to see what I can do before it comes to that.
Thanks in advance.
Thanks in advance.
