Hi there,
I have been on this forum before but didnt manage to fix my problem, what with being away this is the first time I have managed to have another look at it.
When I go to start my motor nothing happens when you turn the key, you can hear the choke engage when you press the key in but nothing else. I have replaced the solenoid and solenoid fuse. I can jump the motor using straight from the starter. Also checked battery connections and output DC on the battery.
Just curious as to other things that I can try.
Cheers
Cheers
