Starting Issues -1981 35 Johnson Seahorse (2 stroke)
Natalbany River Rat
Hey, everybody.
New to the forums, and to boats in general. Have been a lot of learning the last 2-3 weeks trying to get my Dad's old Johnson running.
It had been sitting for about 17 years. I changed the old hoses and spark plugs. Tested the the spark and it was working. I then cleaned the carb, and used a rebuild kit. Put it in a drum of water and it started 2nd pull. I let it run for a few seconds and then killed it because I knew the water pump and impeller were old and wanted to change that first before I really tried to run it.
I then took the lower unit off and changed the pump pump housing and impeller, plus put new gearcase oil in.Put it in the river and it started 2ndoing or 3rd pull. I wasn't sure how long it would take to start spitting water, so I panicked after 10 seconds and killed it. Went through a mental checklist and just figured it would take longer to start spitting. Wouldn't start for a bunch of pulls. Then got it started a few times and it started spitting (Thank the Lord). However, at this time it would only run for 5-10 seconds and big down and die. Tried it again the next day and it started 2nd pull for about 20 seconds and died. Couldn't get it started again. Came back to Ithe yesterday and it started on first few pulls again. It ran for a few seconds like before and then died again. Then it wouldn't start again after that. It seems to start on the 1st few pulls and then bog out, and not start again. Not really sure what I am doing wrong. It's probably something simple that I'm missing as my experince boat engines is limited. Any help would be greatly appreciated as I wanna get out and get some perch.
Don Hansen
Are you pushing the choke knob in as soon as the motor starts. That's the way it is with my 1980 35 hp. But then I have to listen to the motor and play with the choke by moving it out about half way if the motor starts to quit. Takes about half minute for the motor to stabilize. That said, be aware that each motor can be a little different.
F3K1HR
Not sure if you have worked out the kinks yet... I am new to boating, just got a 78' 14' starcraft with a 35 johnson of the same year. I'm really happy with the boat and motor, BUT it does not like to idle in neutral, especially when I first start it up. It takes a little throttle to get it going, then I get it in gear as soon as I can. Once there it runs like a top. It tops out a 25 mph and I usually cruise at 20ish on plane, once its hot I can drop it down to idle and shift to neutral, it'll run for a while, but eventually it will cut out. Same procedure as before.
oldboat1
'81 (e.g., J35RCIG) should have the old fashioned idle adjustment needle at the top of the carb (knob on the face of the air horn(?) If the carb is clean, that air/fuel adjustment should be sensitive. Opening setting is typically 1 1/2 open (counterclockwise) from seated. Then adjust after the engine warms up. Try leaning it out (clockwise) until the motor wants to stall, then back it out about 1/4 turn. Adjustments are small -- about 1/8 turn. You may find that you need to open up the needle (richer) about 1/4 for cold starting, until it warms up. In addition, make sure the choke plates are actually closing tight when you set the choke (need to get in there and push on the plate with a finger to test). For starting, might want to run with half choke until it warms up. Fresh, clean fuel at 50:1.
Lord won't help with the water circulation/cooling (maybe the fishing, though -- can't hurt to ask). Need to replace the impeller to make sure it's pumping -- particularly good idea to replace it if operating in river water (silt) -- hard on impellers.
