Sean Leonard
- Dec 31, 2011
- 11
I recently purchased a well used 1978 Mercury 800 80hp outboard and I am working on getting it running. The previous owner could not tell me the last time it ran. I have replaced a good portion of the wiring and now I am getting spark. Now the issue is fuel. I tried priming and starting but it wouldn't fire.
First I checked the hoses starting at the fuel tack and working towards the carbs. All check out fine and were moving fuel along when the primer bulb was sqeezed.
Next I tried using starter fluid (I know this is a huge debate but it's already done so I can't undo it). The motor fired right up then died. A few more attempts and it was running fine. I let it warm up and then set it to idle.
After a few more minutes I turned the motor off and tried to start it again without the use of starting fluid. It still wouldn't start.
I plan to remove and clean the carbs as the motor has been sitting for an unknown time and I don't know what the previous owner did prior to taking the motor out of service.
What I can't seem to figure out is why this motor will not start by priming. Once it's running the fuel pump seems to be working fine.
Any suggestions would be welcomed.
