4Winns2
- Nov 2, 2006
- 327
Re: Starting issue or seized engine???
What caused the heat was water flow starvation- -broken water inlet hose on the outdrive. When I put her "to the floor" out of the hole is when she overheated and busted the crank. I just didn't think the crank could bust even with the heat.
The mechanic working with me said we'll know when we put the crank in whether the split caused the "block to spread."
Damn water inlet hose. I don't think I'd be here now if I'd known it was busted.
It's possible that there was a hariline fracture in the crank when the engine was "remanufactured". Might have just needed a little bit of heat/oil starvation/shock, to finish it off. There's no telling, really.
If you're going to stick with the old block, make sure you break out the micrometers/slide caliper, and some telescoping gauges, and make sure everything's still in spec. Might be worth it to take it to a machine shop and have the block magnifluxed/x-rayed, to check for cracks or other "invisible" damage to the block. It'd sure be a bummer to put all the time and money into this engine, only to find out that there were other problems with it.
Good luck!
