starting and voltage problems 2002 125hp carb 2plus2
dromann
I have a problem starting it when its cold it has good spark carbs are clean and the motor runs good once warm. But it takes several tries and I have to give it a lot of throttle to get it to fire and continue to run. The choke seems to work properly. The air screws are set at 1 1/2 turns and I have adjusted them a turn in each direction to see if that would help. Any help would be great. Also it is very smokey.
Also the motor hooked up to a voltage meter puts out no juice when motored up or trolling any ideas on what would cause this? I can fish a couple of days but eventually the volts drop to low to start. This motor is a tiller if that maters any.
