hi everybody, I need some help please...
just got this engine from a boat project
trying to work out if this will start
tried to do a compression test, but it's very hard to turn with the compression tester,
and I noticed the prop will always turn even in neutral and I cannot find a spot where it won't, googled and found it may be control box problem, will try to see if it helps when I disconnect all linkages tomorrow...
few questions,
1) where do I connect to jump start the starter without connecting the battery and ignition keys
2) What is that corroded blue thing on the port side?
3) is the missing fuel hose connector on SB side supposed to be connected to fuel tank?
4) I think that is the throttle linkage that is disconnected on port side?
5) where could I find out where everything connects on the engine so I could confirm all the wires are connected to the right spot?
few questions,
