starting a 92 40hp merc has it got a choke?
gros21
well ive got a 92 jet 40 outboared i got it from a mate it hasnt been run in 6 months.
has it got a choke?
also whats the starting procedure, i used the fuel had pump thing, then used the primer on the top of the cowling then just pulled, gave up after 10 attempts.
any tips?
Texasmark
Re: starting a 92 40hp merc has it got a choke?
First of all, a 40 Jet it is probably a 50 or 60 propped engine which is a 3 cylinder advanced design which incorporates a lot of changes including the fuel "enhancement " valve (choke equivalent). It is electrically controlled by the ignition switch.
Turning the switch to on/start and pushing in on the key activates it. The valve opens and allows fuel to flow into the intake manifold making for a very "rich" environment to enhance starting. When engine is running on it's own, just take your hand off the key, the plastic base the key is mounted into pops out about 1/4" and the valve is turned off.....if the engine stutters, push in on the key till it clears then turn it loose.
Fast idle is imperative in a successful "first start of the day". After that, if the engine remains warm, normal idle position is adequate and you don't have to push in on the key to activate the enrichment. If warm and doesn't want to start then treat it as a cold start procedure.
The squeeze bulb on the fuel line is there to fill the carburetor bowls with fuel. When the engine is mounted on the boat and in a vertical position, with fuel line connected and tank vent open, gently squeeze the bulb and after several squeezes it should start to firm up and you should stop when it feels full in your hand. Set your idle to fast idle, turn the key to on, push in on it, and rotate to Start while holding it in. After a period of time....dependent on how long it takes fuel to make it to the combustion chamber which, among other things, is impacted by how long it has been since you ran the engine last, the engine should lite off.
Time on the starter is limited because the starter can overheat. If you attempt to start for like 15-30 seconds and you don't get a hit, squeeze the bulb till firm again. Wait a couple of minutes. If you go through the procedure again and it doesn't hit, you have something that needs attention.
HTH,
Mark
gros21
cheers for the help mate its a 4 cylinder 2 carb model serial 0d042033
it is only pull start with no electrics
also what postion is the kill swich meant to be on the tiller handle i presume its up
ok so more squeezes on fuel line bulb, what about the primer on top of the cowling next to the pull start.
also knowing its a manual model does it have a choke
