STARTING 69 100hp Evin
Bru45
Well,I found a good deal on an old 100hp,however I tried to start it and the start tried to start but no luck I even had a bit of electrical smoke after a few try's from the starter it seemed it didn't want to engage.So I think the starter needs to be changed.The last owner said it was at 90psi in all cylinders when he last used it and he had to change the plugs,cleaned fuel lines to get a good day out of it and it looks like a new pulse pack was also installed.
Is it worth trying to save???? thanks for any help and where can I find good parts/
In Oregon
coolguy147
Re: STARTING 69 100hp Evin
well first off i would check compression in the motor to make sure the motor u got is acually good or not. then so on and forth. u check spark after. etc to get running nice and good
tx1961whaler
How long did you have the starter engaged for? Meaning how long did you twist the key for each time you tried to start it?
Was the fuel line bulb pumped up good and hard?
Was the engine choked?
Was it in a barrel or on a garden hose adapter?
Bru45
Thanks Battery was bad.replaced it cleaned the spark plugs and sprayed out carbs,pumped the fuel line,It turned over slow and it did try to start and I;'ve had a couple of good back fires to scare the wife .I'm using a tub of water to make sure the inlets are underwater.
I've used the choke switch a couple 0f times but not sure how long I should keep it on.I've kept the key turned just so I had a few rotation.Pumped the bulb too much extra gas came out the exhaust.Used the lean rich control arms and it seemed to turn over when the arms were in the middle,tried too rich and too lean also.Can I use a rope of a air wrench to get it going ?I haven't tried checking spark yet just assumed since I cleaned them.....you know.I have a buddy coming over later to help me so we'll see.
Thanks for all you help please any thing else you guys can think of please let me know.
Thanks
Bru45
Is there a good on-line down loadable manual for the 69 100hp Evin???
coolguy147
seems like he hasnt used it for a long time.
porbably try to clean all ur battery and electrical connections ground batt cables connections to starter etc.
might need a carb clean to start off
Bru45
True,
Do you know what cylinder I need to get the piston to TDC before I try to go any deeper as to timing etc?.I'll take the carbs off in the next few days,just gumout or use something else for a deeper clenz/.?any on-line manuals you can suggest?
Thanks
Bru45
#1 starboard cylinder I found it
