Starting 3hp Evinrude
ke4dc
I just picked up a 3 hp Evinrude 2cy<br />It had about 2 hours time on it. It was stored<br />for awhile but dealer preped for storage.<br />It runs well. One problem I have is starting <br />warmed up motor. When motor is shut down after<br />running and warming up I must pull choke out<br />all the way and pull once. Then I set choke out quarter way and pull once or twice to start <br />motor. should't the motor start right up when<br />warm without touching choke? This happens immediately after shuting down motor. I am new<br />to outboards so advise would be appreciated.<br /><br />Thanks, <br /><br />Alan
Xcusme
Re: Starting 3hp Evinrude
Alan,<br />Welcome to the forum!<br /><br />You didn't mention the year of your motor or how long it has been in storage. A guess would be a problem in the low speed idle circuit being partially clogged and or a mixture screw out of adjustment. A carb cleaning and a check of the mixture settings are next. Be sure of the fuel/oil mix and that the motor is does not overheat (old water pump impeller).
alcan
Hi alan<br />Some motors require more choke than others. All motors may need some choke when warm. This depends on where the pistons come to rest when stoped. My guess is that you are not setting the throtle control to the start position. The main funtion for the start position is this sets the timing for the easiest start. This needs to be done hot or cold. It is true of course that we get away with not doing this step on a warm motor quite often.
D
DJ
Guest
ke4dc,<br /><br />That engine should start very easily. You should be able to think it started. ;) Just kidding.<br /><br />If it is an older model-mid sixties. It probably still has the cork float. Those were troublesome and would lead to flooding. Believe it or not, that engine needs choke when flooding. :eek:
R.Johnson
DJ is right these little engines will start with a dirty look. Does this engine have two needle valve's? If so the top one is slow speed, bottom, high speed. Both have to be in proper adjustment. There is a ceramic type filter that screws into tank outlet. These sometimes get gummed up.Here is why we need model numbers when posting. OMC made these engines for years, but they did make minor changes. Later models had a fixed highspeed jet.
Paul Moir
There seems to be some confusion here:<br />
If that's a '60s or '50s 3hp, I'll be shocked!<br /><br />Please, ke4dc, can you tell us the year and model number?
ke4dc
Thanks for help guys<br /><br />The model number of this <br />3 hp Evinrude is: E3RETB Serial B 09009882<br /><br />Any info based on this model number would <br />be appreciated
