Starting 25 hp evinrude
moore0361@msn.com
I have a 1990 25 hp evinrude. It won't start useing the electric start, the starter spins but will not jump up and spin the fly wheel. If I pull start it, it starts right up. Have a new battery. I touched two screw drivers to the celinods and the starter spins but will not jump up and spin the fly wheel.Sprayed wd40 on the starter shaft, hoping it would losen it up but didn't work. Any suggestions?
skelly
Re: Starting 25 hp evinrude
I had a problem like that on a 85 johnson 25hp,I just put light wt electric motor oil on the shaft that the engadger slids up & down on, it worked for me. The manual also suggest this, Hope this helps you! SKELLY
OBJ
Moore....I think Skelly hit it right on the head.
