Starting - 1998 5 hp Evenrude
Andyz
The motor is only used occasionally on my sailboat. It is normally stored inside the boat. <br />Yesterday it would not start. I pulled and cleaned the plug (it seemd to have a some gas on it). The motor caught once for a second but would not stay on. I put store and start in the gas when i bought it in June. I am using the internal tank since the with the external tank I had to keep pumping the bulb. :confused: <br />Thanks,<br />Andy
OBJ
Re: Starting - 1998 5 hp Evenrude
Hi Andy, could you post the model number of the engine? Can't seem to find a 98' 5horse with a built in gas tank or did you mean a different source of gas?
Andyz
The model number is E5RLEC the S/N is S15002804<br /><br />Thanks,<br />Andy
Andyz
Also wondering if ther is a god FAQ other link or out there that would help me solve my problem??<br />Thanks,<br />Andy
marinegrh
sounds like a clogged carb, how long has it been sitting and inwhat weather conditions, compression fire and fuel,, check those first, keep us infoed, <br />id bet a beer on a dirty carb
catfish1
andy, i'm wondering if you have ever started this motor by yourself? because it sounds to me like you may be flooding it.<br />bet a beer on it! just kidding :D <br />i really would like to know a little history on this motor.
Andyz
I bought the motor new (from Defender)- probably in the Spring of 2000. It replaced a 1968 6hp evinrude. I use it as little as possible (25hrs total) since I can sail on and off my mooring. I only reall yneed it to get under a drawbridge for winter storage. It is stored locked to the mast during the summer and in the garage in the winter.<br />I have the marina winterize it and I use less than 3 gallons of gas a season. I have been putting store and start in the gas when I buy it at the suggestion of the mechanic. I drain the tank and replace the gas each season. <br /><br />I replaced the plug tonight and got it started - even though the old plug did not look worn at all. <br /><br />After letting it run I dhut off the fuel line petcock ant let it run dry. <br /><br />What can I use to clean the Carb or do I have to take it off. <br /><br />I visited west marine today but the Evinrude book on 2 to 70 Hp outboards that covered 1998 did not include any 5Hp models.I think it was published by Clymer. Any suggestions for a book??<br /><br />Thanks<br />Andy
