starter won't stay ingaged
gmax
I have an 1983 150hp johnson and when i try to start the motor the starter turns the motor over but than kicks out before the motor can start.Any ideas ?Thanks for any help.
bob johnson
Re: starter won't stay ingaged
weak starter , weak battery or both. I was getting that often in the bitter cold of winter.... the motor starts to fire...I am guessing the flywheel over comes the starters gears push and forces the gear back down, but ther wasnt enough MOMENTUM to sustain firing.
you could also be missing spark in one or more holes. make sure the motor is primed correctly....
there may be another reason, but your symptoms were the same as mine and I explained how i over came my issues.
hope it works for you
bob
Will Bark
On my 87 150hp when it is cold weather I have to advance the out of gear throttle just a touch so that the engine will fire and start, every engine is somewhat different but this is how I have to do it. Good luck
Chris1956
Normally the starter will be kicked out, when the motor fires. I would make sure the motor is choked properly for starting and the throttle is advance properly, and see if it works better. How does it restart after it is warm? Same issue?
