Re: Starter wont engage on 93 Merc 200 Offshore
Hello Nicko;<br />Did you do a drop load test?<br />Use a meter to read the voltage getting to your starter while being cranked. full 12 volts, chances are the starter is poor. Less then 10-10.5 volts check connections, do the same test on the selinoid, work your way back to the battery.<br />Good Luck, Rob
