I have a 1974 50 HP Johnson that has a remote control box. I recently had the Remote control box re-built, and before I started it up again I cleaned out both carbs, as the engine was generaly dirty when I got it. After cleaning the carbs I realized that the starter no longer had enough power to crank the engine (some times the pinon gear will not engage), I now have to crank the engine by hand with pull rope (this was not the case before control box rebuild).
I have preformed a voltage drop test throughout the starting curcuit as suggested by my Clymer's manual, and all of the connections and components seem to be suficiently clean and not causing to much resistance.
My question is: My clymer's manual suggest testing the "safety switch" in the trouble shooting section, is this refering to the nuetral start switch in the control box? and seeing as my starter is turning, is there any reason to test the "safety switch", or should this only be done if the starter will not turn? Seems to me that my problem might be worn brushes in the starter, but I do not know, I have only worked on pull string engines before.
thanks.
PS. I have cleaned all connections and my battery is showing 12v.
thanks.
