Starter spins wrong way Johnson GT 150 1987
marinemike43
When I try to crank the engine the starter just spins ,notice its spinning the wrong way.when I turn it by hand the right way it will engage
Anyone know whats wrong?
Thanks Mike
jriegle04
Re: Starter spins wrong way Johnson GT 150 1987
did something change? was it working before and now it isn't?
marinemike43
Got the boat from a friend
First time I ever tried to turn it over
jriegle04
did he say it ran? i would make sure the battery is fully charged and spray a little wd-40 on the starter shaft and try again.
jriegle04
are the battery terminals on the right posts of the battery?
marinemike43
Its spinning clockwise
Mike
JB
Starter motors are series wound. They will not reverse direction just by reversing the applied voltage.
You can reverse the direction of a series wound motor by reversing the brushes.
I know of no other way to make that happen.
Sorry, clockwise doesn't register with me as right or wrong. Either you are mistaken or somebody screwed up (fixable) your starter.
