Starter Removal
Biggy0000
I have a Johnson Outboard 28hp motor in which was left to me from my grandfather but it wont run. I hook up the power to it and turn the key and the gear on the starter spins but it wont engage to the flywheel. I handspun it into the flywheel and turned the key and it wont spin the flywheel. I wanted to remove the starter and clean it and check it. How do i remove it from the motor without tearing the whole motor apart. <br />I dont know the year or anything else about it besides the following information: Model# J28ESLCUC
rickdb1boat
Re: Starter Removal
Razorback <br /><br />Before you start tearing the starter off, first shoot a little WD-40 on the starter shaft just above the gear. That should free it up so it slides up the shaft when you hit the key. Next, make sure the battery is good and fully charged, remove and check all the connections from the battery to the starter for corrosion and tightness. Many times it's loose or corroded connections that are the problem and not the starter. (Not enough juice to the starter to turn the motor over.) If that doesn't get it to turn over, then let us know and we can help you get the starter off(Simple). How long has this motor been sitting?<br /><br />BTW-That's a 1987 Model ya got there. I have an 89' Model! Great Motors!!
