Does the whole pull start assembly have to be removed to take off the starter motor on this relic. ?
H hula777 Recruit Joined Apr 21, 2011 Messages 1 Apr 21, 2011 #1 Does the whole pull start assembly have to be removed to take off the starter motor on this relic. ?
M Maxz695 Guest Apr 21, 2011 #2 Re: starter removal / merc. 110 elect. 9.8hp don,t know your engine but as long as it doesn,t interfere I don,t see why you should have to remove the assembly unless it,s blocked in after you disconnect the starter
