Starter problems
Dan H. Sr.
I have a "77" Johnson 140 that I recently bought, but have have been having starter problems. The bendix will engage with the flywheel but will not disengage. Hoping it was a bad spring I replaced it, but no luck!!! Looking at the bendix itself, the "teeth" appear worn and bent. It's a 10 tooth Bosch starter---is it possible to purchase just the bendix? I can't find a part number on it. Also I see my coils are somewhat "leaky", without replacing is there any type of fix for this?<br />Thanks in advance for any help or suggestions.<br /> Dan
OBJ
Re: Starter problems
Fishn dan...welcome to the forums.<br /><br />The Bosch drive can be replaced. Ash for part number 385949. Around 24.99 American. Have you lubricated the shaft the drive runs on? No lube can cause the bendix to stick. Drop a few drops of WD-40 or light lube on the shaft and work it up and down by hand a little to get the lube down into the bendix thread. Then try it again. My save a few bucks.<br /><br />Coils....are you referring to the ignition coils mounted on the engine or the stator under the flywheel? If you got "stuff" leaking from either, replace them. Don't try and fix. Replace.<br /><br />Ignition coils are PN 502888. Around 35.65.<br /><br />Keep us posted and good luck.
Dan H. Sr.
OutboardJim--Thanks for the advice!! I found out that the spring I bought for the starter was to small actually making the bendix bind-up. As for the lube, I was useing a heavy- duty grease, thus not letting the bendix slide back down. The ignition coils are what I was referring to, but I'll change them out as you suggested. thanks for your help!!! :) Dan
oldboat1
The teeth in the bendix gear are normally chamferred on the edges -- not wear, although it may appear that way.
