FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
The other day the starter on my 1982 25HP Johnson outboard ( Model # J25TELCNB) simply became week! I got it started, but after it stalled, it wouldn't start again. At times the "drive pinion" won't rise, but when it does it is having trouble turning the crank. I have a strong battery, so could it be the starter going bad? If so, could I just replace the "brushes?" Those starters cost as much as I paid for the motor, so I would like to see if it can be repaired/rebuilt first. Any helpful ideas?
First clean all battery connections both on battery and engine side. Remove grounding screw from engine and clean off all corrosion if any.
Check voltage into the solenoid and after the solenoid when cranking.
i just had these same issues, rebuilt starter, cleaned connections, charged battery, now it works like a champ, only cost 50 bucks to redo the starter. good luck
