Starter Problem
gm280
A few things can cause that. First the starter isn't spinning over fast enough. Second, the starter needs cleaned and repaired. Third, the shaft could be dirty and stuck.Forth, your starting battery is not fully charged or the battery is weak. So you can disassembly the starter, clean it, grease the bushings and/or bearings and make sure the brushes are good. Clean the commutator and reassembly it. Also test your battery or take it for a load test to verify it is up to the job still. JMHO
Oh, and before I forget it, :welcome: to iboats...
welcome aboard.
most of the time, if you can swear that the battery is good (charged and able to put out enough current), the connections to the starter need cleaning. first, remove the two bolts fastening the starter to the block. clean the pad that the starter sits on and the back of the starter using 3M scotchbright. get the surface shiney enough that you would eat off it. rebolt in place. next, the positive connection cable at the starter needs to be cleaned....then work your way to the battery.
remember, each connection needs to be clean enough you would eat off it.
once done and the motor starts like a dream, come back to each connection and seal with marine electrical varnish.
