Starter Problem
beachbum15
I have an old 1986 OMC seadrive 225hp. The starter continues to crank only after the engine starts? I would think the soleniod is bad but this occurs only after the engine starts.
oldcatamount
Re: Starter Problem
Sometimes a weak battery will cause that problem, if not, then it's probably the solenoid.
texasabil
Re: Starter Problem
I agree weak batteries and solenoids can cause funny things to happen!!! check your voltage should be 12.6!!! if that doesn't do it Ignition switch can also be going bad!!
Bob_VT
Re: Starter Problem
Is there grease on the shaft to the gear? If that gets a build up of garbage it tends to make that hang up....... clean the shaft undr the spring and lightly oil it.
