I have a starter problem with a 1975 70 HP Johnson Seahorse. When I turn the ignition key to the start position, the starter will turn but the pinion gear ( if thats the right description?) will not rise to engage the flywheel and start the engine. If I keep the key in the start position, the starter starts revolving faster but the pinion still does not engage. A couple of times I raised the pinion gear with a screwdriver to engage the flywheel and then tried starting - nothing happened - no rotation, noise or anything else. The battery is nearly new and fully charged.
Earlier this year I had starting problems and after cleaning and polishing every visible ground connection and then spraying them with WD-40, the engine worked well. At that time I also sprayed a small amount of WD-40 on the worm gear of the starter. Everything worked well until a few days ago when I was winterizing it and when I tried to start it I encountered the starter problem described above.
Can someone provide me a diagnosis or solution to this problem? Thanks.
