Pthieberger
Thread starter- Joined
- Mar 3, 2013
- 5
I have a problem and was wondering if someone out here could help....I had a bad starter and replaced it last week my evinrude started right up. I went out today to try to start it and it started after a couple turns then died which usually happens its an 89 finally got it going again and it cut off. When I went to start it again the starter engaged flywheel but only turned it one or two teeth now if I stay on the key it will turn it 3 or 4 teeth every couple seconds. Is this the sign of a low battery or what?
Thanks!
Thanks!
