I spent all day chasing a no start issue with my boat, batteries charged up, and everything seems ok, but when I went to turn the key, nothing, not even a click. After chasing wires and attempting to check fuses, I used a screwdriver to bypass the solenoid, the starter would "spool" but would not crank the motor, am I right in assuming the starter and solenoid have gone bad?
I read a thread the other day about how much of a pain swapping the starter can be when it's tucked under the starboard riser and exauhst manifold, I've come to the realization that I will have to dissessemble these in order to get to it.
That being said, I've seen that I will need a new manifold gasket, but other than that, are there any other things that I need to look out for so I can put it back together and everything work properly?
Thanks guys,
Dan
Thanks guys,
Dan
