Starter on 67 golden meteor 100 hp
masonrc43
ok I have a question on removing the starter from this motor because it just clicks and does not turn over I have sheck the connection s charged battery and even tried jumping the starter but is does nothing
F_R
There are two bolts that run all the way through the starter, heads on the bottom. There is a support bracket on the bottom of the starter. Remove the bolt from that. Un-screw the thru-bolts and the starter will come down and away.
