E25TECCA 25hp electric start unit, mounted on a 16 foot boat purchased for my Grandson to duck hunt with. Bought at auction, "starting running good used boat", visited with previous owner after the auction, watch video of boat on lake. Long story, home lower in tub of water, starter spins up but slips on the fly wheel.
Determine that the front mounting bracket of the starter has been drilled out, cause the front mount, stud has broken in the casting and does not maintain a proper alignment of the starter gear and flywheel.
I have tried to repair the stud using high temp epoxy, covered with regular gray epoxy. Broke on the first test turn of the key.
Any ideas for a quality repair of the stud?
When drilled out larger no doubt weakened the mounting area, causing the casting to break out.
Can I remove the unit, lay on it's back face up, and melt aluminum around a replacement stud the proper size?
Thoughts, ideas? Does the story make sense?
Webekin
Webekin
