Starter goes on on running engine, 1979 85HP Johnson
andreipou
Hi, I have 85 HP 1979 Johnson (85ML79R).
I noticed that when accidentally turned key to START position while engine was running that starter went on crashing bendix teeth.
I thought that starter is supposed to be blocked from running while engine is running.
Am I wrong or something is not right with motor?
Tnx.
Time to review the wiring.----Risk of damaging ignition and battery charging components now.
F_R
Tnx.
Wrong. Nothing blocks the starter except the driver. Don't turn it to "START" and it won't happen.
F_R
Perhaps you are thinking of safety switches that prevent starting the motor with the controls set in gear. That's a different subject.
Just reread the post.----If motor is running in neutral then yes the starter will engage if you turn it to start.------My truck likely has a feature on it's computers to prevent that.----Can't lock the doors when key is in ignition.-----Diesel engine starts up when I am working in the garden with key in my pocket too.-----I want to disable that remote start feature.
oldboat1
toggle switch under steering column (under dash panels)? Switch it off.
