starter,fuses, ignition, etc issues...related or not?
ovlov5353
I had this posted under general maintenence then realized I should probably post it here. Any advice would be greatly appreciated.:
Hello and thanks for checking my post out. (sorry for the length) I am a newbie and I am in need of some help. Here is the background:
1994 OMC 3.0- Recently bought boat with existing starter problem (starter hanging and not disengaging and blowing ignition fuses). I then replaced the starter with an aftermarket brand marine starter and everthing worked fine. Before and after the starter replacement I had blown a few ignition fuses intermittently so I upgraded to a 20 amp from a 5 amp (sounded more reasaonable for an ignition fuse according to some people that I have talked to). Thought I had all my issues solved. Just spend 3 days on the lake and made it through all three days and only blew 1 ignition fuse (figured I either had a short somewhere or a bad ignition switch- no big deal). I did also occasionally have an issue with the new starter again not disengaging (kinda pointed back to ignition switch again). Feeling pretty good about my first trip out and having a good idea of how to track down the few things I still need to tinker on, I then proceeded to start the boat to go load it and the starter is now not engaging to the flywheel, a completely new issue. It spins and you can barely hear a small "click" of the starter making very light contact with the flywheel. I tried turning the motor to find a better place on the flywheel and either it is not the flywheel or I did not turn it enough. Here are my questions:
1- would an ignition switch possibly cause all these issues (or at least most of them?
2- Is it more likely that I got a defective starter?
3- Is it more likely that I am dealing with several different issues (defective ign switch, short, bad flywheel, and/or defective starter)? Which of these would be more likely to be related and be caused by the same part?
I really need someone to point me in the right direction. I really don't want to take it to the local highway robbery boat mechanic if I can avoid it. I will probably be starting with a new ignition switch (like $15). It can't hurt. Then what? Please help.
fat fanny
Re: starter,fuses, ignition, etc issues...related or not?
I have been having similar issues minus the starter problem but Maybe this will help some? With a test light hook to good ground touch the B terminal of the switch test light should light, Now move to the S terminal and turn switch to the start position the light should light up,if not the switch is bad!. The rest of this info is in the stickies thread at the top of this forum under testing your engines starting system but I for one can tell you traking down a dead short is like "looking for a needle in a stack of needle" ( Tom Hanks saving private ryan) good luck and if all else fails start checking continuity on every wire in the entire wiring harnes especially the starting circuit it just took me a week to totally unwrap and chaeck then re-wrap and rout mine time will tell on the results.
