ThndrSki
Thread starter- Joined
- May 27, 2011
- 71
After putting in new exhaust and riser elbows, changing plugs, all fluids, I started the engine.
It started right up and I ran it on the trailer (on the hose with the flusher) for about 20 minutes until it was all warmed up. All functioned properly, and I was showing a good charge on my two batteries with a Perko Switch set to "All".
After I shut the engine of to check oil levels, etc, I went to start the engine up again, and starter just clicked. Went to trim the motor up, and the trim (solenoid?) just clicks rapidly. Sounds like a battery issue but that seems hard to believe as the Gauge is showing 12V.
Do you think this is a battery issue or something more dubious? How should I troubleshoot as it WAS JUST RUNNING FINE.
My engine is a 1995 Mercruiser 5.7L Alpha One
