starter 83 versus 89 johnson
Joe Fisherman
I am having problems with my starter it turns over really slow its a 89 65hp johnson.I have an old blown motor 83 50hp johnson are these starters interchangeable????????
Hooty
Re: starter 83 versus 89 johnson
If it looks like it would fit and had the same number of teeth, I'd give it a shot but are you sure it's your starter and not a loose or dirty connection?<br /><br />c/6<br /><br />Hooty
D
DJ
Guest
Joe,<br /><br />Slow turning starters are usually caused by excess resistance in the battery cables.<br /><br />Clean and check all of the connections-ESPECIALLY the ground on the engine block. Remove it and completely and clean it up.
