Foam/ Wood sandwich stringers
Hello all, Im restoring a 21.5ft 1979 Fiberform sportsman. The stringers were made a little differently in this boat and I am replacing them. Originally they were plywood incased in fiberglass on either side of a bottom fuel tank. With a piece of plywood layed over the tops on either side, fiberglassed over, filled with flotation foam, and a molded fiberglass floor insert resting on the transom box and attached to the rub rail. It seems the fiberglass gave most of the strength. I do not wish to use plywood agian. My Idea is to take closed cell foam (The 4X8 blue sheets at Lowes and Home Depot), use liquid nail to sandwich the foam with 1/8 inch pine or fiberglass wall covering (the 4X8 pannels sold in the same locations), sealing the ends with paint or RTV, and then fiberglass over them. Since the foam melts in contact with resin, the wood or roughed up fiberglass and pained ends would act as a barrier and would considerably strengthen the foam. This would be laid out as a box and filled with floatation foam. Anyone ever try this? Do you think its a good idea or just rubbish? I know the fiberglass alone is strong enough because i ran the boat when the stringers were mush and there was no flex whatsoever. Any suggestions would be appreciated. Thanks.
