Start up problem. coil pack wiring?
niatyson55
I can't find a coil pack wiring diagram for a 1986 johnson 140hp outboard j140txocdc. Any suggestions? Just replaced the power pack and not sure if coils are wired correctly. When I try to start the motor it will fire up for 1 or 2 seconds then die out.
jakedaawg
Have you checked for spark with an open airgap spark tester? If not, do so. Preferably one that lets you check the spark from all four wires at once. Spark should snap nice bright blue accross a 7/16" gap while cranking.
niatyson55
Thank you for the response. I will try this as soon as I can and let u know how it turned out.
