I got a fiberglass Starcraft V160, 1982. It is really hard to see the inside of the transome on this boat. Transom is spongy. As a temporary remedy I did the 1/4" aluminum plate and angle iron thing to get me through the summer. I will be replacing the transom over the off season. From what I can see, the plywood doesn't go all the way to the bottom of the hull. Has anyone seen this before. My plan was to remove the top. Replace plywood, coating it with epoxy resin, and then just epoxy resin to seal everything up. will this work. I guess I will know more when I get started. Will post pics when I get started also. Surte would love to do the CC conversion on this.
