FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Do I have to disassemble my entire steering column in order to straighten it ? The wheel shifted to one side and is throwing my cable drum off-line . ( First time at this ).
Is it a cable and pulley system (using vinyl coated thin wire cable) or is it a single cable system? Please explain that the steering column shifted.....you might need to rebuild the dash
Thank-you for your response, I ended up taking the whole column out . it's a single cable pulley system (with the coated wire) . when I replace the cable to the drum , should I add both ends ,with the motor straight , or do I and majority of cable from one side ? the cable runs down both sides of the boat. Oh yea, my dash seems fine , the main center nut under the column cover was not tight enough. straightened it up and snuged it up tight .
