Starcraft MDX 191 - Dashboard Material
creativedge llc
Good Morning,
I was hoping with the wealth of knowledge here, someone could help me with some information related to a 2017 Starcraft MDX 191 and sourcing a part. Specifically, the dash panel and its specs. I've attached an image of the panel.
I do not need to replace the part itself although any information would be helpful I'm sure.
What I need is to source a supplier for -- either a blank sheet of the material, or the dash panel blank to be routed/lasered/cut to custom. It will need to match the OEM "horizontal wood grain" pattern.
Any info or referrals are greatly helpful and appreciated!
Thanks.
Ayuh,...... Welcome Aboard,...... I believe yer options are try Starcraft, or fab up yer own,.....
creativedge llc
Thank you.
yes, starcraft was among my first attempted points of contact.
As it were, it is being fabricated. I need to match the aforementioned patterning specific to this boat. Working from a blank would be great.
But even any information simply about that wood pattern specific to this boat make and model (2017 Starcraft MDX 191) would be terrific. Suppliers I've tried didn't have any blanks that matched. I could even work with a digital image of the pattern/color. Any info would be helpful.
briangcc
I'd take a pic of the dash and then go to a vinyl sign shop. Have an oversized vinyl sheet (wrap) made up with the correct grain pattern/color. Pop the gauges out, apply vinyl, then cut openings where you need them.
But that's just me...
Toyelectroman
I originally tried to make a copy of my starcraft dash out of starboard as I didn't want to hack up my original dash but couldn't get it 100% with the curves of the original. Ended up going through the dealership to order me a blank dash. Unfortunately they come with the gauge holes pre cut, so I don't think that will help you
