Starcraft mariner 21 with roller trailer ?
sronza
I am rebuilding my 21 ft mariner with a roller trailer . Local owner of same model boat told me roller trailer will weaken and losen rivets .
Any thoughts is this correct ?
JD in Milwaukee
Re: Starcraft mariner 21 with roller trailer ?
Think about what you've said. Now repeat it over and over for a bit. What do you think?
Pugetsound
Well my 22 holiday with a OB has the trailer that came with it since 1975 not a loose rivit to be found and it is a Roller Trailer just make sure its adjusted for the boat. Should be ok . I have a bunk on my smaller 16 ft and really like the easier way to off load and load.
talltx
I'm against the idea of rollers for a riveted boat, even if the rollers don't touch the rivets. Bunks are padded and spread the weight out over a greater area. Aluminum is soft. Rollers are more likely to cause the aluminum to stretch over time, which also stretches the holes that the rivets go through. Once that happens, it can break the seal that keeps the water out and weaken the hull by loosening the rivets. When you're towing and you hit a bump in the road, think about the force of the rollers pressing against the hull in the same place each time. Then multiply that hundreds of times over the life of your boat.:eek: Oh, and yes, I agree with JD. It is wise to heed the knowledge of fellow boat owners, especially if they have the same boat as you and perhaps owned it longer. I hope this helps.:)
64osby
Mines on a roller. Shorelander 32 roller if I remember (Ran out of finger and toes). Original to the boat 1984. It always been trailered. Boat is dry and no loose rivets.
A long ways to crank and I need some loading guides but it works great.
