starcraft hoilday 14 restore
larlarsa
Summer was come silent,is time to do something on my boat,i planning to do a xterm make over,i will try to post pic on every step i work,but some time too concentrate ,always forgot to take pic,
i start from the bow area , it is hard to take the bow cap out,after that i split the rub rail insert apart, unrivert all the rail to stern,this make it easy to replace transom.
take the steering away and unattached the motor.now i have a very clean hull to start with.
Frist i need to replace my transom,i ham the splash well tube out,and i use 2 hour to take the old transom out,can't take with one pieces.i just cut two 3/4' ply and willing to use PL4000 glue together, i am thinking of add an aluminum sheet to cover the expose area,otherwise water can easy to wet it again.
larlarsa
Re: starcraft hoilday 14 restore
steering is out.
larlarsa
empty hull.
larlarsa
transom is out.
bananaboater
Ensign
Yup, making great progress. This is fun. Keep us posted.
We love to know where folks are in general. If you go to your profile page you can put in a city, state if you want.
Sometimes we find fellow restorers right next door.
Huron Angler
Looks like a great start on the rig there...those little holidays are sweet boats, she should be zipping right around with that 50hp:D
larlarsa
not too much work on the boat today ,just strip the old floor support and try to clean up the hull,but i miss the connect from my hight jet washer to garden hose,i give up today,wait the transom glue sit for 1 day.
CBGale2
Looks alot like my Falcon 14, did yours have a splash well in it? Nevermind, I found your before pictures.
larlarsa
i take the splashwell and going to cut it shorter,the splashwell is important for the hull structure,i will have a deck extend the length longer than before to hold both side of the hull.
larlarsa
come home late today, so just glass the one side of transom in two coat.tomorrow will glass the other side with glass mat.
larlarsa
Dirty job today , I glass the other side of the transom with glass matt,this is not easy than I though , it take 1 L to soak up all the Mat ,the resin dry up very fast, I must doing it very quick,but I am concern about the thickness after the glass, i don't know it will fit in the transom tray not not, looks like 1/4" increase , maybe need to sand down a little bit. Did people paint the transom after glass? if does , what kind of paint to use? I want it match my splashwell color,why Starcraft expose the transom out , it easy to geting wet? Why don't use a pisces of aluminum to cover it. Most other modren boat builder cover it all.
larlarsa
glass on
larlarsa
Use some aluminum to brace the floor bottom.
jasoutside
That extra aluminum will make for a super strong deck, nice work!
ezmobee
I agree. That's some nice structure there. Looks great.
larlarsa
Ok, after the transom is done,i put it back and then drill two more hole for the Live well intake and out.i also cut the splash well a little bit shorter,then build a deck extend to hold both side of the boat,it made it more stronger than before .
larlarsa
i am going to use 5/8" plywood for all the deck and floor.
