I have a 1973 starcraft 120 hp mercruiser and can anyone explain this to me? It's my understanding that you shouldn't seal the sides of the deck to the insides of an aluminum hull. OK, if this is so, then how can you have any hope of not having waterlogged foam beneath deck (assuming it is used)? Also, still undecided as to whether I should use 1/2" or 3/4"plywood for decking. Thanks in advance.
