starcraft american 76 with wakeboard pylon?
bs911
hi, I have a sc american OB which will be restored. Hopefully no floor repairs needed.
At the same time I would like to install baseplate for a pylon:
you think the boat is strong enough, anyone any experience with it?
thank you!
Chinewalker
Re: starcraft american 76 with wakeboard pylon?
Check the floor and stringers carefully, as I haven't seen many that weren't at least somewhat deteriorated. Be sure to seal any screws that go through the floor. Also, the keel is dead center under the floor, so if you have a peg or anything that goes through the floor, keep that in mind. Not a good idea to drill a large hole into the keel as it will create a weak point...
Should be a good ski boat - they plane off quickly and have a fairly small wake for a V-hull.
- Scott
