- Mar 8, 2009
- 44,428
Running a standard Bravo 3 @ 2.0 ratio behind a 502 cuin 415 HP in my Formula. According to what I've found the standard B3 can handle 400 HP. Had the drive gone through 4-years ago because it was make more whine then I was use to when idling. Rebuilder (Certifed Merc tech with his own shop) found nothing out of tolerance. My previous B3 never made the noise and I still have it, but it is old style with added piece on the rear (B1 with a tail) for B3. At the end of last season found a bit of foreign matter in the lower section of the drive, found nothing in the top. Material was showing the slightest bit of gray in the lube and could see very fine particles a metallic substance. Drained the lube for 3 days and then refilled.
Pulled the plugs this season and found the same similar issue with slight gray in the bottom and green/black in the top. My rebuilder is gone and therefore I'll be taking it to someone else so hence the question.
Is it to much HP for the drive or most likely something else?
